Τα παρακάτω είναι ότι βρήκα. Ξεκίνα να παίρνεις τηλέφωνα και αν βρεις άκρη είσαι ωραίος.
Αν όχι τότε πας για άλλον συναγερμό.
Copy paste από άλλο φορουμ
Adjust and Test sensitivity level of the shock sensor
1.Turn the ignition switch on/off 3 times and stay in off position
2.Push the valet switch(to koumpaki katw apo thn sela tou sunagermou) 6 times and holding the 6th push until three chirps with a long chirp is hearing then release the valet switch.You are now in Alarm feature "III" programming mode.
3.Press and hold F button on the transmitter for 2 seconds. 2 LED flash, 2 siren/horn chirps to indicated the unit is ready to accept adjustments of the schock sensor.
4.Press F button on the transmitter once will decrease sensitivity level by one, each time an decrease is made the siren/horn chirp will respond with 1 chirp, while 2 chirp indicates minimum sensitivity
5.Press the (anoixto louketaki) button on the transmitter once will increase sensitivity level by one, each time an increase is made the siren/horn chirp will respond with 1 chirp, while 2 chirp indicates the maximum of sensitivity.
6.Hit the bumper or strong metal part of the motorcycle to test the threshold level of the sensor.
a)Activate the warn-away (first stage the shock sensor) the siren/horn will emit a short chirp.
b)Activate the full alarm (second stage the shock sensor) the siren/horn will emit a long chirp.
7.When you are satisfied with the setting, press the (kleisto louketaki) button once time to lock the adjustment.
Note: If 20 seconds of inactivity expire, or (kleisto louketaki) button on the transmitter is press during the above steps, the unit will exit program mode and return to the disarmed mode. A 3 long chirps to confirm exit.
εκει που λεω ανοιχτο κ κλειστο λουκετακι ειναι τα αντιστοιχα συμβολα στο χειρηστηριο σου.
https://el-gr.facebook.com/elser.caralarm
Εταιρεία: ELSER HELLAS Α.Ε.
Νομός: ΑΤΤΙΚΗΣ
Πόλη: ΑΘΗΝΑ
Διεύθυνση: Καλλιρρόης 29
T.K.: 11743
Τηλέφωνο: 2109248286, 2109248288
Διεύθυνση: Ν., Λεωφόρος Βουλιαγμένης 69, Αθήνα 116 36
Τηλέφωνο:21 0924 5445
Ώρες: Ανοιχτά σήμερα · 9:00π.μ.–5:00μ.μ.
Πάνε και μια βολτα ή τηλεφώνησέ του από κάτω. Αφού έχει elser μπορεί κάτι να ξέρει
Αραμπατζής Γεώργιος
Ελευθερίας 17, Αμπελόκηποι,
τκ 56123 - Θεσσαλονίκη
Τηλ: 2310 743 289
Alexandros . ..
♬ ♫ ♪ ♪ ♫ ♬ Thessaloniki - Macedonia - Hellas - Europe - World - .............
